[Proj] Using EPSG codes with cs2cs
Tue Oct 5 15:28:06 PDT 2010
R.Vives wrote:
> Hello,
> Is it possible to use EPSG codes with cs2cs? I tried the following command:
> "cs2cs +init=epsg:4326 +to +init=epsg:32632"
> but it didn't work, i only get this message:
> "Using from definition: init=epsg:4326
> Rel. 4.7.1, 23 September 2009
> <cs2cs>:
> projection initialization failure
> cause: Unknown error
> program abnormally terminated"
Rafael,
It works for me!
Perhaps the epsg init file isn't being found, or your lacks code 32632?
Try setting the PROJ_DEBUG environment variable to the value "5" and running
again to see all files accessed.
Best regards,
