[Proj] Using EPSG codes with cs2cs
R.Vives vivesraf at gmail.com
Tue Oct 5 16:05:43 PDT 2010
Thank you for your quick answer,
Where do you modify the PROJ_DEBUG environment variable? (I am a beginner
with the PROJ.4 library)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-EPSG-codes-with-cs2cs-tp5605047p5605212.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
