[Proj] Using EPSG codes with cs2cs
Tue Oct 5 16:19:49 PDT 2010
R.Vives wrote:
> Thank you for your quick answer,
> Where do you modify the PROJ_DEBUG environment variable? (I am a beginner
> with the PROJ.4 library)
Rafael,
It is an environment variable.  It depends on your operating system
environment.
For a Windows cmd.exe command shell do:
   set PROJ_DEBUG=5
   cs2cs.exe ...
For unix with a bourne style shell use export:
   export PROJ_DEBUG=5
   cs2cs ...
For unix with a c shell use setenv:
   setenv PROJ_DEBUG 5
   cs2cs ...
Unfortunately you gave no clue to your operating system or I would have
provided an example in my first reply.
Best regards,
