[Proj] Using EPSG codes with cs2cs
R.Vives
vivesraf at gmail.com
Tue Oct 5 16:37:18 PDT 2010
Sorry, I should have tell you, I work on Windows XP.
I managed to modify the environment variable just like you said and when I
enter my command
I have the following new message: "pj_open_lib(epsg): call
fopen(C:PROJSHARE\epsg) - failed"
"C:\gdal_ogr>cs2cs +init=epsg:4326 +to +init=epsg:32632
pj_open_lib(epsg): call fopen(C:PROJSHARE\epsg) - failed
Using from definition: init=epsg:4326
Rel. 4.7.1, 23 September 2009
<cs2cs>:
projection initialization failure
cause: Unknown error
program abnormally terminated"
In fact, I don't have any PROJSHARE folder on C:, so I guess this is what is
wrong.
Regards,
Rafael
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-EPSG-codes-with-cs2cs-tp5605047p5605271.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
