[Proj] Using EPSG codes with cs2cs
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 5 17:06:42 PDT 2010
R.Vives wrote:
> Sorry, I should have tell you, I work on Windows XP.
> I managed to modify the environment variable just like you said and when I
> enter my command
> I have the following new message: "pj_open_lib(epsg): call
> fopen(C:PROJSHARE\epsg) - failed"
> "C:\gdal_ogr>cs2cs +init=epsg:4326 +to +init=epsg:32632
> pj_open_lib(epsg): call fopen(C:PROJSHARE\epsg) - failed
> Using from definition: init=epsg:4326
> Rel. 4.7.1, 23 September 2009
> <cs2cs>:
> projection initialization failure
> cause: Unknown error
> program abnormally terminated"
> In fact, I don't have any PROJSHARE folder on C:, so I guess this is what is
> wrong.
Rafael,
I'm not sure where you got your cs2cs.exe binary, but hopefully that also
came with the "epsg" file somewhere in the tree. If you set the PROJ_LIB
environment variable to point to the directory containing the epsg init
file then things will hopefully work.
eg.
set PROJ_LIB=C:\PROJ\NAD
cs2cs.exe ...
If you need to you can grab a recent epsg init file from:
http://svn.osgeo.org/metacrs/proj/trunk/proj/nad/epsg
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
