[Proj] Using EPSG codes with cs2cs
R.Vives
vivesraf at gmail.com
Tue Oct 5 17:28:41 PDT 2010
Problem solved!
I specified the path to my 'gdal_ogr' folder (where are located cs2cs.exe
and the epsg file).
set PROJ_LIB=C:\gdal_ogr
Then I typed my command again:
C:\gdal_ogr>cs2cs +init=epsg:4326 +to +init=epsg:32632
pj_open_lib(epsg): call fopen(C:\gdal_ogr\epsg) - succeeded
45.0 10.0
4714852.20 1361287.34 0.00
It works!!!
Thank you very much,
Best regards.
Rafael
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-EPSG-codes-with-cs2cs-tp5605047p5605366.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
