[Proj] EPSG CS not supported, but the epsg file contains the correct definition
SAEZ Laurent - SG/SPSSI/CPII/DOM/ETER
Laurent.Saez at developpement-durable.gouv.fr
Thu Oct 7 09:29:41 PDT 2010
Hi all,
I have to add support for new CRS in my mapfiles.
New EPSG code, 4559 (Projected CRS for French Antilles - Guadeloupe and
Martinique) replaces 2989.
The ellipsoide is the only thing different (GRS80 instead of WGS84).
So I add the EPSG:4559 definition in my epsg file.
<4559> +proj=utm +zone=20 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m
+no_defs <>
I use MapServer 5.6.5 with proj 4.7.0 (on Debian 64bits).
When I call a GetMap using EPSG:4559 the image rendered is "wrong".
EPSG:4559 and EPSG:2989 are almost identical and the images should be
approximately similar.
So, I test my EPSG code with testepsg.
If I don't specify the epsg file location ('/opt/mapserver/bin/testepsg'
EPSG:4559), I have :
"ERROR 6: EPSG PCS/GCS code 4559 not found in EPSG support files. Is
this a valid
EPSG coordinate system?
ERROR 1: Error occured translating EPSG:4559."
If I specify the file location ('/opt/mapserver/bin/testepsg'
'/opt/mapserver/share/proj/epsg' EPSG:4559) :
"Validate Succeeds.
WKT[/opt/mapserver/share/proj/epsg] =
PROJCS["unnamed",
GEOGCS["GRS 1980(IUGG, 1980)",
DATUM["unknown",
SPHEROID["GRS80",6378137,298.257222101],
TOWGS84[0,0,0,0,0,0,0]],
PRIMEM["paris",2.3372291666985],
UNIT["Meter",1],
PARAMETER["standard_parallel_1",46.8]]
PROJ.4 rendering of [/opt/mapserver/share/proj/epsg] = +proj=lcc
+lat_1=46.8 +lat_0=46.8 +lon_0=2.33722917 +k_0=0.99987742 +x_0=600000
+y_0=2200000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +pm=2.3372291666985
+units=m +no_defs
this a valid
I use to add EPSG codes in my mapfiles. It's the first time I have this
problem.
It seems that sometimes it is not sufficient to add a definition in the
file EPSG...
I have read this thread ("Unsupported SRS but available in epsg file") :
http://www.mail-archive.com/gdal-dev@lists.osgeo.org/msg04926.html
My GDAL_DATA environnement variable is well defined. I tried to add the
definition in cubewerx_extra.wkt without success.
Any idea ?
I send this message on this list but I can't know what application is at
issue: GDAL or PROJ?
NB: I apologize for my bad English.
More information about the Proj
