[Proj] EXCEPTION_ACCESS_VIOLATION (0xc0000005) after many successful calls to pj_init_plus
Aaron Friesen aaron at cartopac.com
Wed Oct 27 16:20:46 PDT 2010
Everyone,
I have an application that runs as a web service.  It
runs for a while, then any call to pj_init_plus with
the same string that has been successfully running
up to that point eventually results in an access
violation during the pj_init_plus call.
Restarting the service clears up the problem for a
while, but once it hits, proj seems to be in a
problem state.
I believe I'm running 4.6.1.
Are there any known problems like this?
Does anyone see a problem with how I am calling proj?
My sanitized code looks like (VS2005, c++):
HRESULT Xform(int numXY, double* x, double* y, int numZ, double* z, char* src, char* dst)
	if (numXY <= 0)
		return S_FALSE;
	if (!x || !y || (numZ > 0 && !z))
		return E_INVALIDARG;
	HRESULT hr = S_OK;
	projPJ srcPJ = NULL;
	projPJ dstPJ = NULL;
	try
		if (numZ == 0)
			z = NULL;
		if (!xformSpec.proj4CfsDefn || wcslen(xformSpec.proj4CfsDefn) == 0)
			throw E_INVALIDARG;
		srcPJ = pj_init_plus((char*)src);
		if (!srcPJ)
			throw E_PROJ_BAD_SRC_DEFN;
		dstPJ = pj_init_plus((char*)dst);
		if (!dstPJ)
			throw E_PROJ_BAD_DST_DEFN;
		int projResult = pj_transform(srcPJ, dstPJ, numXY, 1, x, y, z);
		if (projResult != 0)
			throw E_PROJ_FAILED;
	catch(HRESULT thrown) { hr = thrown; }
	catch(...) { hr = E_UNEXPECTED; }
	if (srcPJ)
		pj_free(srcPJ);
	if (dstPJ)
		pj_free(dstPJ);
	return (FAILED(hr) ? hr : S_OK);
Thanks,
Aaron
