[Proj] truble to translate coordinates from WGS84 to EPSG:31287
Jean-Claude Repetto
jrepetto at free.fr
Thu Oct 28 01:54:11 PDT 2010
Le 28/10/2010 10:11, Markus Hetzmannseder a écrit :
> Hallo,
> i have trubles to translate WGS84 coordinates to EPSG:31287. This is
> needed at the Openstreetmap Projekt for the correct projection of OSM-data
> to the austrian geoimage.at WMS-service. For the OSM-editor JOSM there is
> a plugin epsg31287, that should do the job and in its calculations it is
> based on proj. That plugin is based an proj is working, its not working
> really correct. It is producing a shift of about 30 metre and that shift
> is only local, in other regions of austria the shift has a different
> length and different direction.
> For debugging that shift i started to use proj directly, and it is
> producing the same shift in its calculations like the JOSM-plugin.
> The correct proj arguments for EPSG31287 should be:
> +proj=lcc +lat_1=49 +lat_2=46 +lat_0=47.5 +lon_0=13.33333333333333
> +x_0=400000 +y_0=400000 +ellps=bessel
> +towgs84=577.326,90.129,463.919,5.137,1.474,5.297,2.4232
> +units=m +no_defs
> For my reference i use the coordinate translation service of geoland.at
> (http://www.geoland.at/geolandcoord/eingabe.aspx)
> The results are for some example points:
> WGS84 proj-EPSG31287 geoland.at-EPSG31287
> 14.2833092 48.3098392 470439.28 490437.40 470507.17 490503.03
> 16.371345 48.211996 625637.33 483542.58 625724.57 483601.75
> 9.747076 47.503042 130035.17 406569.01 130056.24 406637.26
> The geoland.at projection is, as far i know, the real projection the
> WMS-service (http://wms.geoimage.at) is using.
> Any hints where the difference could be come from?
> thx a lot
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Hello,
I get the same results as geoland.at :
cs2cs +init=epsg:4326 +to +proj=lcc +lat_1=49 +lat_2=46 +lat_0=47.5
+lon_0=13.33333333333333 +x_0=400000 +y_0=400000 +ellps=bessel
+towgs84=577.326,90.129,463.919,5.137,1.474,5.297,2.4232 +units=m +no_defs
470507.17 490503.01 -45.92
16.371345 48.211996
625724.58 483601.74 -44.45
9.747076 47.503042
130056.92 406637.21 -48.36
Jean-Claude
More information about the Proj
