[Proj] truble to translate coordinates from WGS84 to EPSG:31287
Markus Hetzmannseder hetzi at algebra.uni-linz.ac.at
Thu Oct 28 03:17:04 PDT 2010
On Thu, 28 Oct 2010, Jean-Claude Repetto wrote:
> I get the same results as geoland.at :
>  cs2cs +init=epsg:4326 +to +proj=lcc +lat_1=49 +lat_2=46 +lat_0=47.5
> +lon_0=13.33333333333333 +x_0=400000 +y_0=400000 +ellps=bessel
> +towgs84=577.326,90.129,463.919,5.137,1.474,5.297,2.4232 +units=m +no_defs
> 14.2833092 48.3098392
> 470507.17	490503.01 -45.92
> 16.371345 48.211996
> 625724.58	483601.74 -44.45
> 9.747076 47.503042
> 130056.92	406637.21 -48.36
Oh thx a lot, i did it that way, to get the wrong results:
proj +proj=lcc +lat_1=49 +lat_2=46 +lat_0=47.5 +lon_0=13.33333333333333
And its looking like that josm-plogin is doing the same. Now i know at
least how to generate the real projektion with the proj-toolbox itself.
Now the plugin should be able to be changed in a similar way to use the
cs2cs arguments.
Markus
