[Proj] Changing projection in OL code
support.mn at elisanet.fi
Tue Aug 2 02:44:26 PDT 2011
Hello,
what "OL code" you are talking about?
Regards: Janne.
Mustafa646 [noorcs22 at gmail.com] kirjoitti:
> I have a shapefile with native projection SWREFF99_1800. For publishing on
> Geoserver, I changed it from SWREFF99_1800 to Spherical Mercator (EPSG:4326)
> by using third party tool ogr2ogr. And finally i published it on Geoserver
> and Displayed it over Google base map in my OL Web Page.
> I want to change this projection (from SWREFF99_1800 to EPSG:4326) by using
> some code in my OL web page instead of changing it by using third party tool
> before publishing it on Geoserver. Is it possible and if yes, then what will
> be the possible code/method for this ?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Changing-projection-in-OL-code-tp6644040p6644040.html
> Sent from the PROJ.4 mailing list archive at Nabble.com.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
