[Proj] Changing projection in OL code
Mustafa646 noorcs22 at gmail.com
Tue Aug 2 05:24:35 PDT 2011
"OL code" means coding by using OpenLayers API Library.
Can i change projection of shapefile published on Geoserver by using
OpenLayers API ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Changing-projection-in-OL-code-tp6644040p6644683.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
