[Proj] Axis order for CRS created from EPSG code
Martin Desruisseaux
martin.desruisseaux at geomatys.fr
Sun Aug 28 06:48:25 PDT 2011
Hello all
Currently, building a Proj.4 PJ structure from a definition string like
"+init=epsg:4326" produces a CRS with (/longitude/,/latitude/) axis order. Using
the "+init=epsg:4326 +axis=neu" definition string produce the
(/latitude/,/longitude/) axis order expected by EPSG. I would like to know what
are the plan for the 4.8 release: do you plan to provide some way to build a CRS
including the "+axis=neu" part from an EPSG code, or is it left to the user?
It is not a request for change, this is just for knowing if users (or
geoapi-wrappers) shall handle the axis order parameter on their side or if
Proj.4 plans to take care of that.
Regards,
Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110828/e0224a45/attachment.html>
More information about the Proj
