[Proj] New proposal of JNI bindings for Proj.4
Martin Desruisseaux martin.desruisseaux at geomatys.fr
Mon Aug 29 09:04:13 PDT 2011
Le 29/08/11 17:41, Eric Miller a écrit :
> But, what is the correct behavior if a pointer argument is null or an array
> size is negative? Call abort()? Would that still crash the JVM?
Calling exit() has been reported to stop the JVM (I didn't tested myself). I
presume that it is the same for abort().
Inside a JNI function, if the arguments were provided by the user who invoked
the function from the Java side, the correct behavior is to throw a Java
exception (NullPointerException or IndexOutOfBoundsException). JNI functions
have a JNIEnv argument which allows interaction with the JVM. So we can throw an
exception from JNI code as below:
         jclass c = (*env)->FindClass(env, "java/lang/NullPointerException");
         if (c) (*env)->ThrowNew(env, c, "/Put some error message here./");
         return; // We need to exit from the C/C++ function.
Of course this apply only to JNI functions. The "normal" C library uses other
mechanisms (typically no check - or if they check, an error code returned as an
int).
     Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110829/4e6256a8/attachment.html>
