[Proj] Are there newer windows builds than 4.4.6?
Kulawik, Norbert
Norbert.Kulawik at geobasis-bb.de
Thu Feb 17 21:35:58 PST 2011
Hello all,
I just downloaded proj.4.4.6 as a windows prebuilt executable, which
appears to be slightly older than the source code version 4.7.0.
I'm experiencing similar problems as described in
http://lists.maptools.org/pipermail/proj/2011-January/005509.html:
Using a cs2cs command line like
> cs2cs +proj=latlong +ellps=clrk66 +nadgrids=ntv2_0.gsb +to
+proj=latlong +ellps=GRS80 +datum=NAD83
(with the ntv2_0.gsb properly installed and all environment variables
set, including debug) the first coordinates I enter (or just pressing
enter with no input) result in the message
pj_open_lib(ntv2_0.gsb): call
fopen(C:\users\Downloads\PROJ.4\proj446_win32_bin\nad/ntv2_0.gsb) -
succeeded
* * 0.000
and the next coordinates I enter give wrong results or zeroes.
Trying other NTv2 grids led me to believe that they are just ignored:
the resulting coordinates do not change when I - for example - enter a
wrong filename for the +nadgrids option. In that case, I get an error
message, though.
I suspect this all is because the windows version of PROJ.4 is a bit
old. Since I have no knowledge or tools to build it myself, is there a
place where newer versions of PROJ.4 are available as an executable
build?
Any suggestions or other causes for this problem would also be
appreciated.
Thanks in advance
Norbert
More information about the Proj
