[Proj] How I assign Projection to shapefiles, so that they fit right on google map
Mustafa646
noorcs22 at gmail.com
Tue Feb 22 00:51:37 PST 2011
I have a shapefile which i want to display over Google Map, The projection
defined in this shapefile is "SWEREF 99 1800". But it could not fit right
over Google Map. How I change/re-project my shapefile so that it fit right
on google map?
shapefile is attached.
Need immediate help ?
http://osgeo-org.1803224.n2.nabble.com/file/n6051523/Parkshp.zip Parkshp.zip
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-I-assign-Projection-to-shapefiles-so-that-they-fit-right-on-google-map-tp6051523p6051523.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
