[Proj] How I assign Projection to shapefiles, so that they fit right on google map
Mikael Rittri Mikael.Rittri at carmenta.com
Tue Feb 22 01:15:36 PST 2011
Hello,
"SWEREF99 18 00" is EPSG:3011.
Google Map uses the CRS that EPSG calls "WGS 84 / Pseudo-Mercator", which is EPSG:3857.
So, using ogr2ogr, I think you can convert your park.shp file into a googlepark.shp
by the command
> ogr2ogr -t_srs EPSG:3857 -s_srs EPSG:3011 googlepark.shp park.shp
But I haven't tried it.
(I think you could omit the "-s_srs EPSG:3011" from the command if you
 had a park.prj file, which would tell ogr2ogr the CRS of the park.shp.
 But it seems you don't have any park.prj file.)
Sources:
http://www.gdal.org/ogr2ogr.html
http://www.epsg-registry.org
Regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Mustafa646
Sent: den 22 februari 2011 09:52
To: proj at lists.maptools.org
Subject: [Proj] How I assign Projection to shapefiles, so that they fit right on google map
I have a shapefile which i want to display over Google Map, The projection defined in this shapefile is "SWEREF 99 1800".  But it could not fit right over Google Map. How I change/re-project my shapefile so that it fit right on google map?
shapefile is attached.
Need immediate help ?
http://osgeo-org.1803224.n2.nabble.com/file/n6051523/Parkshp.zip Parkshp.zip
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-I-assign-Projection-to-shapefiles-so-that-they-fit-right-on-google-map-tp6051523p6051523.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
