[Proj] How I assign Projection to shapefiles, so that they fit right on google map
Mustafa646 noorcs22 at gmail.com
Thu Feb 24 07:53:45 PST 2011
I used the above command, but i could not succeed. it displays message:
failed to process SRS defination: 3011
can you explain, what is wrong ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-I-assign-Projection-to-shapefiles-so-that-they-fit-right-on-google-map-tp6051523p6060815.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
