[Proj] Single Proj.4.7.0 Definitions File
support.mn at elisanet.fi support.mn at elisanet.fi
Mon Jun 6 06:09:05 PDT 2011
Hello,
here is a link to a fresh (4.7.0 fresh) .pin file.
http://www.polardist.com/pub/proj4.7.pin
[size 1.30 MB (1,368,201 bytes)]
It is compiled using Proj.4.7.0 distribution files:
epsg, esri, esri.extra, GL27, IGNF, nad27, nad83
other.extra and world
There are 7793 proj.4 definitions. It is a text file and
can be examined and edited with a std. text editor. The
old fashion "title=" statements are converted to "#"
comment lines. Comments are inside the <block>
and white space is converted to CRLF for clarity.
Names are converted from plain numbers to include
the source, such as ESRI:32149.
Here is an example definition block. The name is
included in the block as a comment line.
# EPSG:32149
# NAD83 / Washington South
proj=lcc
lat_1=47.33333333333334
lat_2=45.83333333333334
lat_0=45.33333333333334
lon_0=-120.5
x_0=500000
y_0=0
ellps=GRS80
datum=NAD83
units=m
no_defs
Regards: Janne.
