[Proj] New Zealand Map grid projection
Hamish
hamish_b at yahoo.com
Sun Mar 27 18:32:11 PDT 2011
Claire wrote:
> I've got a problem with the results of the NZMG projection.
> Using proj 4.7.1 (23 sept 2009), I got :
> >proj -I +proj=nzmg
> #2864916.8 6160570.9
> #177d8'19.853"E39d41'14.816"S
> But when I check my results with the Land Information New Zealand (LINZ)
> I got :
> That is more than 6 minutes difference in Latitude !...
> Both seems to use the same datum NZGD49.
Hiya Claire, hope you are enjoying being back on dry land! :-)
The `proj` program does not apply datum shifts, you need to use `cs2cs`
instead.
the expanded version looks like:
cs2cs +proj=nzmg +datum=nzgd49 +lat_0=-41.0 +lon_0=173.0 +x_0=2510000 +y_0=6023150 +a=6378388 +rf=297 +no_defs +nadgrids=nzgd2kgrid0005.gsb +to_meter=1.0 +to +proj=longlat +datum=wgs84
a shorter version looks like
cs2cs +init=epsg:27200 +nadgrids=nzgd2kgrid0005.gsb +to +init:epsg=4326
Also if working on/near land* you'll want to use the NTv2 distortion grid,
not the 3 or 7 term +towgs84 parameters. Make sure that both sides of the
"+to" include a +datum definition.
(* don't use NZMG out of view of a trig station if you can help it, it
goes a bit wonky offshore)
regards,
Hamish
(Otago)
More information about the Proj
