[Proj] New Zealand Map grid projection
Claire Castellazzi
c.castellazzi at niwa.co.nz
Mon Mar 28 13:58:20 PDT 2011
Hi Hamish (funny to hear from you here!), Hi Frank,
Thanks a lot for your help.
I'm sorry, I'm a neophyte with proj in particular, and geodesic in general,
and unfortunately, something is still bothering me...
Actually, I need to convert my coordinates into utm60 and I was trying to use cs2cs.
(cs2cs +proj=nzmg +to +proj=utm +south +zone=60)
It was not working so I went step by step, using proj to have a look what was going on...
I thought that the usual datums where associated to each projection as standard parameters...
Well, now that I understand that you actually need to specify your datum if you want the datum shift to be performed,
I still have a problem :
> cs2cs +proj=nzmg +datum=nzgd49 +lat_0=-41.0 +lon_0=173.0 +x_0=2510000 +y_0=6023150 +a=6378388 +rf=297 +no_defs +nadgrids=nzgd2kgrid0005.gsb +to_meter=1.0 +to +proj=utm +zone=60 +south +datum=wgs84
Using to definition: proj=utm zone=60 south datum=wgs84
Rel. 4.7.1, 23 September 2009
<cs2cs>:
projection initialization failure
cause: unknown elliptical parameter name
program abnormally terminated
The same command with output in latlon +datum=wgs84, gives the same error...
Using to definition: proj=longlat datum=wgs84
<cs2cs>:
Thanks for any help.
Claire
PS : Hamish, I know that NZMG is not the best choice, specially offshore, but it's not my choice...
The data comes from MED and has been labeled only with NZMG.
And I need to put it in the Landmark soft Seisvision, where I'm using the projection UTM60S to builds my maps...
And yes, I feel much better on land !...
Please consider the environment before printing this email.
NIWA is the trading name of the National Institute of Water & Atmospheric Research Ltd.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110329/7fa51af9/attachment.html>
More information about the Proj
