[Proj] New Zealand Map grid projection
Mon Mar 28 14:30:12 PDT 2011
On 11-03-28 04:58 PM, Claire Castellazzi wrote:
> I still have a problem :
>  > cs2cs +proj=nzmg +datum=nzgd49 +lat_0=-41.0 +lon_0=173.0 +x_0=2510000
> +y_0=6023150 +a=6378388 +rf=297 +no_defs +nadgrids=nzgd2kgrid0005.gsb
> +to_meter=1.0 +to +proj=utm +zone=60 +south +datum=wgs84
> Using to definition: proj=utm zone=60 south datum=wgs84
Claire,
I believe the problem is that PROJ.4 names are case sensitive, and
WGS84 needs to be in capitals.  Try +proj=utm +zone=60 +south +datum=WGS84
Best regards,
