[Proj] New Zealand Map grid projection
Claire Castellazzi c.castellazzi at niwa.co.nz
Mon Mar 28 14:50:36 PDT 2011
Hi Frank,
Thanks, You're right, it is case sensitive and it now gives a result with +datum=WGS84.
But the result is wrong...
The result is actually the same as without specifying the datum, so I guess the datum shift has not been performed...
$ cs2cs +proj=nzmg +datum=nzgd49 +lat_0=-41.0 +lon_0=173.0  +x_0=2510000 +y_0=6023150 +a=6378388 +rf=297 +no_defs +nadgrids=nzgd2kgrid0005.gsb +to_meter=1.0  +to +proj=utm +zone=60 +south +datum=WGS84
2864916.8 6160570.9
511905.895606922.76 0.00
Without any datum : $ cs2cs +proj=nzmg +to +proj=utm +zone=60 +south
2864916.8 6160570.9
511905.89   5606922.76 0.00
The right answer (from LINZ) should be :
511924.6   5607118.0
I even tried :
$ cs2cs +proj=nzmg +datum=nzgd49 +lat_0=-41.0 +lon_0=173.0  +x_0=2510000 +y_0=6023150 +a=6378388 +rf=297 +no_defs +nadgrids=nzgd2kgrid0005.gsb +to_meter=1.0  +to +proj=utm +zone=60 +south +datum=WGS84 +lat_0=0.0 +lon_0=177.0 +x_0=500000 +y_0=10000000 +a=6378137 +rf=298.257223563 +to_meters=1.0
2864916.8 6160570.9
So what's wrong ?...
Please...
Thanks.
Claire
>>> Frank Warmerdam <warmerdam at pobox.com> 3/29/2011 10:30 AM >>>
On 11-03-28 04:58 PM, Claire Castellazzi wrote:
> I still have a problem :
> +to_meter=1.0 +to +proj=utm +zone=60 +south +datum=wgs84
> Using to definition: proj=utm zone=60 south datum=wgs84
Claire,
I believe the problem is that PROJ.4 names are case sensitive, and
WGS84 needs to be in capitals.  Try +proj=utm +zone=60 +south +datum=WGS84
Best regards,
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
Please consider the environment before printing this email.
NIWA is the trading name of the National Institute of Water & Atmospheric Research Ltd.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110329/6f55aba5/attachment.html>
