[Proj] PROJ4 7 parameter datum shift Beijing 1954
Geoff Shipton geoff at tritonimaginginc.com
Mon Mar 28 11:44:52 PDT 2011
Greetings to all,
I am looking for some assistance with a problem we have using the PROJ4
libraries, I am not a programmer neither am I geodesist – however I know
enough to be dangerous! Please bear with me
We have a customer in Shanghai China that is uses something he refers to as
the Shanghai Local projection.
It is built on Beijing 1954 and uses that datum, the 7 parameter shift he
gives are as follows:
TX:          170.076
TY:          154.924
TZ:          97.308
RX:         1.666408
RY:          0.872624
RZ:          -8.648183
K:            0.00000186
The Ellipsoid is Krassovsky 1940
The local coordinate system parameters are TM:
CM: 121.46716061
Scale: 1.0
False Eastings: 0
False Northings: -34587140.589
I constructed the following PROJ4 string:
+proj=tmerc +lat_0=0 +lon_0=121.46716061 +k=1 +x_0=0 +y_0=-3457140.589
+ellps=krass
+towgs84=170.0760,154.9240,97.3080,1.6664,0.8726,-8.6482,0.00000186 +units=m
+no_defs
However I am not getting the correct results, for example.
WGS84 coordinate
31° 17' 27.50965" N          121° 35' 54.41138" E        13.7729
Should give Shanghai Local coordinate
12501.0727E       6164.1228N
However the position from PROJ4 is:
12953.30E            6042.97N
We very rarely need to invoke this type of transformation so it’s quite
possible something is awry with our code, but I sure would appreciate any
thoughts on the problem.
Geoff Shipton,
Triton Imaging Inc.
Customer Support.
Capitola CA.
The information contained in this message may be privileged or confidential
information intended solely for the use of the addressee(s).  Any views or
opinions presented in this communication do not necessarily represent those
of Triton Imaging, Inc.  If the reader of this message is not the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this communication is strictly prohibited.  If you have received
this communication in error, please immediately notify me and you are hereby
instructed to delete all electronic copies and destroy all printed copies.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110328/250de912/attachment.html>
