[Proj] PROJ4 7 parameter datum shift Beijing 1954
Noel Zinn (cc)
ndzinn at comcast.net
Mon Mar 28 12:11:00 PDT 2011
First thing to try is to reverse the signs of the three rotations. I believe that proj.4 uses a “position vector” rotation sense. This may be a “coordinate frame” transformation. Judging from the RZ value and the differences in Eastings, this might work (but I haven’t run the numbers). -Noel
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
Sent: Monday, March 28, 2011 1:44 PM
To: proj at lists.maptools.org
Subject: [Proj] PROJ4 7 parameter datum shift Beijing 1954
Greetings to all,
I am looking for some assistance with a problem we have using the PROJ4 libraries, I am not a programmer neither am I geodesist – however I know enough to be dangerous! Please bear with me…
We have a customer in Shanghai China that is uses something he refers to as the Shanghai Local projection.
It is built on Beijing 1954 and uses that datum, the 7 parameter shift he gives are as follows:
TX: 170.076
TY: 154.924
TZ: 97.308
RX: 1.666408
RY: 0.872624
RZ: -8.648183
K: 0.00000186
The Ellipsoid is Krassovsky 1940
The local coordinate system parameters are TM:
CM: 121.46716061
Scale: 1.0
False Eastings: 0
False Northings: -34587140.589
I constructed the following PROJ4 string:
+proj=tmerc +lat_0=0 +lon_0=121.46716061 +k=1 +x_0=0 +y_0=-3457140.589 +ellps=krass +towgs84=170.0760,154.9240,97.3080,1.6664,0.8726,-8.6482,0.00000186 +units=m +no_defs
However I am not getting the correct results, for example.
WGS84 coordinate
31° 17' 27.50965" N 121° 35' 54.41138" E 13.7729
Should give Shanghai Local coordinate
12501.0727E 6164.1228N
However the position from PROJ4 is:
12953.30E 6042.97N
We very rarely need to invoke this type of transformation so it’s quite possible something is awry with our code, but I sure would appreciate any thoughts on the problem.
Geoff Shipton,
Triton Imaging Inc.
Customer Support.
Capitola CA.
geoff at tritonimaginginc.com
The information contained in this message may be privileged or confidential information intended solely for the use of the addressee(s). Any views or opinions presented in this communication do not necessarily represent those of Triton Imaging, Inc. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please immediately notify me and you are hereby instructed to delete all electronic copies and destroy all printed copies.
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110328/2de4cd5c/attachment.html>
More information about the Proj
