[Proj] unable to install proj.4 on fedora Linux
    Frank Warmerdam
    warmerdam at pobox.com
    Tue Mar 29 07:39:32 PDT 2011
On 11-03-29 05:32 AM, VIDIT KUSHWAHA wrote:
> Hi
> I am new to proj4. I tried to install proj.4 4.7 on fedora
> linux. Configure command works fine without giving any error. But when I give
> make command error occurs. output of make is given below:
> Making all in nad
> make[1]: Entering directory `/root/Desktop/gis/proj-4.7.0/nad'
> make[1]: *** No rule to make target `GL27', needed by `all-am'.Stop.
Vidit,
I inspected proj-4.7.0.tar.gz and it has this file in the nad directory.
Do you have it?  On the download server I did:
warmerdam at xblade13:/osgeo/download/proj$ tar tzvf proj-4.7.0.tar.gz |grep GL27
-rw-r--r-- 501/501         694 2008-10-18 09:08 proj-4.7.0/nad/GL27
This is one of few upper case files.  Any chance you are doing this on a
filesystem that does not preserve case?
Best regards,
More information about the Proj
