[Proj] Proj Digest, Vol 82, Issue 7
Melita Kennedy
mkennedy2 at earthlink.net
Tue Mar 29 20:14:53 PDT 2011
-----Original Message-----
>Date: Mon, 28 Mar 2011 11:44:52 -0700
>From: "Geoff Shipton" <geoff at tritonimaginginc.com>
>Subject: [Proj] PROJ4 7 parameter datum shift Beijing 1954
>To: <proj at lists.maptools.org>
>It is built on Beijing 1954 and uses that datum, the 7 parameter shift he
>gives are as follows:
>TX: 170.076
>TY: 154.924
>TZ: 97.308
>RX: 1.666408
>RY: 0.872624
>RZ: -8.648183
>K: 0.00000186
Geoff,
In addition to changing the signs of the rotation parameters as Noel suggested, also convert the K: 0.00000186 to ppm, 1.86 and try that.
A lesser possibility is that the directionality is wrong and these parameters convert from WGS84 to Beijing 1954.
Melita
More information about the Proj
