[Proj] +a argument different than I expected
Sun Nov 13 12:17:33 PST 2011
On 11-11-13 11:39 AM, Michael Speth wrote:
> Greetings,
> I am using SVN Revision: 2113. I have found that the +a argument doesn't match
> the value found in P->a. Here is an example:
> proj +proj=healpix -f '%.'$PERCISION'f' +lon_0=45 +a=3.0 +R_A +ellps=WGS84 -E <<EOF
> 0 0
> EOF
> The value of P->a is 2.996646.
> Is this correct?
Michael,
I don't really know the answer, but I'm guessing the +R_A is adjusting the
semi major and semi minor axis a bit.  I honestly don't even know what
you meant by the the mix of +a, +R_A and +ellps.
Best regards,
light and sound - activate the windows | http://pobox.com/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
