[Proj] +a argument different than I expected
Michael Speth spethm at landcareresearch.co.nz
Wed Nov 16 12:42:18 PST 2011
Hi Frank,
   I think I am confused on how the arguments should be used.  Let me
describe what I am trying to test.  Here are the following scenarios to
test the projections I am working on (HEALPix & rHEALPix):
* Forward Sphere
* Inverse Sphere
* Forward Ellipsoid
* Inverse Ellipsoid
Case 1 - Forward Sphere Parameters
+lon_0=45 +a=1
Case 2 - Inverse Sphere Parameters
-I +lon_0=45 +a=1
Case 3 - Forward Ellipsoid Parameters
+lon_0=45 +a=1 +e=0.5
Case 4 - Inverse Ellipsoid Parameters
-I +lon_0=45 +a=1 +e=0.5
Where I think the following:
* lon_0 is the central meridian
* a is the radius of the sphere or ellipsoid
* e is the eccentricity
Thanks for your help.
On 14/11/11 09:17, Frank Warmerdam wrote:
> On 11-11-13 11:39 AM, Michael Speth wrote:
>> Greetings,
>> I am using SVN Revision: 2113. I have found that the +a argument doesn't match
>> the value found in P->a. Here is an example:
>> proj +proj=healpix -f '%.'$PERCISION'f' +lon_0=45 +a=3.0 +R_A +ellps=WGS84 -E<<EOF
>> 0 0
>> EOF
>> The value of P->a is 2.996646.
>> Is this correct?
> Michael,
> I don't really know the answer, but I'm guessing the +R_A is adjusting the
> semi major and semi minor axis a bit.  I honestly don't even know what
> you meant by the the mix of +a, +R_A and +ellps.
> Best regards,
Michael Speth
Research Systems Developer
Landcare Research
