[Proj] apply plane rotation after transverse Mercator projection
Duffy, Garret
garret.duffy at nuigalway.ie
Wed Oct 12 04:13:02 PDT 2011
I would like to design a projection that is similar to a TM projection
except append the parameter "XY_Plane_Rotation", i.e. rotate the XY
axes. Is this possible to do in PROJ4? I note the tmerc doesn't have
an alpha parameter or similar. I already tried using RSO but it's
overkill for what I want to do, all I want to do is apply a simple
cartesian rotation to the projected XY axes.
Another thing I tried was editing a PRJ file for a TM projected data and
then appending "PARAMETER["XY_Plane_Rotation",XX]" to the file but that
doesn't seem to work.
Do I have to define a custom PROJCS that is based on tmerc but allows
for the XY_Plane_Rotation parameter?
Any suggestions gratefully would be (very) gratefully received as I have
been trying to do this supposedly simple thing all week.
Regards,
Garret
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111012/d8e0a3bf/attachment.html>
More information about the Proj
