[Proj] apply plane rotation after transverse Mercator projection
Clifford J Mugnier
cjmce at lsu.edu
Wed Oct 12 06:50:44 PDT 2011
I don't know if PROJ4 has it, but the Rosenmund projection as used in Switzerland sounds like what you want.
Clifford J. Mugnier, C.P., C.M.S.
Chief of Geodesy,
Center for GeoInformatics
Department of Civil Engineering
Patrick F. Taylor Hall 3531
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA 70803
Voice and Facsimile: (225) 578-8536 [Academic]
Voice and Facsimile: (225) 578-4578 [Research]
Cell: (225) 328-8975 [Academic & Research]
Honorary Life Member of the
Louisiana Society of Professional Surveyors
Fellow Emeritus of the ASPRS
Member of the Americas Petroleum Survey Group
From: proj-bounces at lists.maptools.org on behalf of Duffy, Garret
Sent: Wed 12-Oct-11 06:13
To: proj at lists.maptools.org
Subject: [Proj] apply plane rotation after transverse Mercator projection
I would like to design a projection that is similar to a TM projection except append the parameter "XY_Plane_Rotation", i.e. rotate the XY axes. Is this possible to do in PROJ4? I note the tmerc doesn't have an alpha parameter or similar. I already tried using RSO but it's overkill for what I want to do, all I want to do is apply a simple cartesian rotation to the projected XY axes.
Another thing I tried was editing a PRJ file for a TM projected data and then appending "PARAMETER["XY_Plane_Rotation",XX]" to the file but that doesn't seem to work.
Do I have to define a custom PROJCS that is based on tmerc but allows for the XY_Plane_Rotation parameter?
Any suggestions gratefully would be (very) gratefully received as I have been trying to do this supposedly simple thing all week.
Regards,
Garret
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111012/181fca24/attachment.html>
More information about the Proj
