[Proj] general question about upgrading PROJ.4
Garret Duffy garret.duffy at nuigalway.ie
Thu Oct 13 02:43:08 PDT 2011
I have installed PROJ.4 version 4.7.0-9.1 using OpenSUSE YaST2 with the
Geo/SLE_11 Repository.
Everything installs fine and according to YaST2, the correct version has
just been installed.
However, when I run /usr/bin/proj, I get the message that version 4.5 is
still installed even though the new version is supposed to be installed to
that location.  I have the same issue with GDAL, I upgraded it but when I
run gdalinfo --version, it states the old version is still installed.
I'm hoping someone can help.
Garret
