[Proj] general question about upgrading PROJ.4
Roger Oberholtzer roger at opq.se
Thu Oct 13 03:15:05 PDT 2011
On Thu, 2011-10-13 at 10:43 +0100, Garret Duffy wrote:
> Hi,
> I have installed PROJ.4 version 4.7.0-9.1 using OpenSUSE YaST2 with the
> Geo/SLE_11 Repository.
If you are using openSUSE, why are you taking things from the SLE_11
repository? Which version of openSUSE are you using?
What do you get for:
	rpm -qa | grep proj
> Everything installs fine and according to YaST2, the correct version has
> just been installed.
> However, when I run /usr/bin/proj, I get the message that version 4.5 is
> still installed even though the new version is supposed to be installed to
> that location.  I have the same issue with GDAL, I upgraded it but when I
> run gdalinfo --version, it states the old version is still installed.
> I'm hoping someone can help.
> Garret
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
Yours sincerely,
Roger Oberholtzer
OPQ Systems / Ramböll RST
Office: Int +46 10-615 60 20
Mobile: Int +46 70-815 1696
roger.oberholtzer at ramboll.se
________________________________________
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
SE-104 62 Stockholm, Sweden
www.rambollrst.se
