[Proj] general question about upgrading PROJ.4
Garret Duffy garret.duffy at nuigalway.ie
Thu Oct 13 04:18:11 PDT 2011
Thanks for the reply.  When I run the command, I get:
libproj0-4.7.0-9.1
proj-4.7.0-9.1
libproj-devel-4.7.0-9.1
I have OpenSUSE 11.0 installed with repositories for 11.1 and 11.2 added to
YaST2
I used SLE_11 because the list of OSs in the GEO repository are:
 Parent Directory                                 -
 CentOS_5/                   10-Oct-2011 02:11    -
 RHEL_4/                     18-Aug-2011 13:59    -
 RHEL_5/                     10-Oct-2011 02:11    -
 SLES_9/                     07-Oct-2011 18:05    -
 SLE_10/                     07-Oct-2011 18:04    -
 SLE_11/                     10-Oct-2011 20:35    -
 openSUSE_11.2/              10-Oct-2011 20:38    -
 openSUSE_11.3/              10-Oct-2011 20:43    -
 openSUSE_11.4/              10-Oct-2011 20:39    -
 openSUSE_Factory/           10-Oct-2011 22:33    -
 openSUSE_Tumblewe
I didn't see an entry for openSUSE 11.0 so I thought SLE_11 was it...  is
that where I went wrong?
I don't use linux every day, I only use it for grass and proj so you
probably see that I am not an expert user by any means...
Thanks,
Garret
"Roger Oberholtzer" <roger at opq.se> wrote in message
news:1318500905.9020.74.camel at acme.pacific...
> On Thu, 2011-10-13 at 10:43 +0100, Garret Duffy wrote:
>> Hi,
>> I have installed PROJ.4 version 4.7.0-9.1 using OpenSUSE YaST2 with the
>> Geo/SLE_11 Repository.
> If you are using openSUSE, why are you taking things from the SLE_11
> repository? Which version of openSUSE are you using?
> What do you get for:
> rpm -qa | grep proj
>> Everything installs fine and according to YaST2, the correct version has
>> just been installed.
>> However, when I run /usr/bin/proj, I get the message that version 4.5 is
>> still installed even though the new version is supposed to be installed
>> to
>> that location.  I have the same issue with GDAL, I upgraded it but when I
>> run gdalinfo --version, it states the old version is still installed.
>> I'm hoping someone can help.
>> Garret
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
> Yours sincerely,
> Roger Oberholtzer
> OPQ Systems / Ramböll RST
> Office: Int +46 10-615 60 20
> Mobile: Int +46 70-815 1696
> roger.oberholtzer at ramboll.se
> Ramböll Sverige AB
> Krukmakargatan 21
> P.O. Box 17009
> SE-104 62 Stockholm, Sweden
> www.rambollrst.se
> Proj mailing list
MB5!.1PT*&@H````-24A$4@```!8````6" 8```#$M&P[````!F)+1T0`_P#_
M`/^@O:>3````"7!(67,```L2```+$@'2W7[\````!W1)344'TPD"%3<BH.WN
MD ```CA)1$%4>-KME3UH$V$8QW]W27.V:6.DQ11:))&"E")-$031H047X806
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M4?JZM[0W'\ Q5S+ B&S?,II"_4_O at C@%)'>#?4^&\1U)#_1%\&\SX\*2`Z5E
M`Y@&9F3WM at Z@B8^CP"AP!X@"!H(8V_/E:<*C-&V]P_TG6G?H^2*L%\I07 at .W
MNCG,-F@)U0U6_F0 at B".R-Y[9VP:>.T9I.?MN)1J.1:2&W"Y!>W<K$&MH51MR
M7RM at Z@8P(GOCF:9+2&;"`(8P]4QV*8>>![,"5FTK\T7(KI7)K;P'4T\",9F)
MS+Y+:,=8>*ALSB^.&*BW7C4`=. 5,+T=V #__T$.'?P3(N;@\5,A'B\`````
(245.1*Y"8((`
end
MB5!.1PT*&@H````-24A$4@```!8````6" 8```#$M&P[````!&=!34$``+&.
M?/M1DP```"!C2%)-``!Z)0``@(,``/G_``" Z0``=3 ``.I@```ZF ``%V^2
M7\5&````!F)+1T0`_P#_`/^@O:>3````"7!(67,```L3```+$P$`FIP8```$
MR$E$050XRYV4:6Q4513'__>]-Z_S9CHS+6VG"Z5I*66 at 34HIH0(I*!;+8ENB
M5F65A"4:1(W$)7S2J!\PT1AB8F*,-E:)0 at 11,2RFH!5,D+!(K=24MA:FG<J4
MMK.]-V^[QP_3`D$3*;^O]^:7_SWGW"/B7G!XE?R:K<U+-NSY<#2B.W0]>5UR
MY^9P+3PZ<85-3N at 1?26U\^?5K7NVYH%E3:;H\_Y\Y%B'/],=[;S4T=?WPZX=
M(","`-)="04)2E[ES.I5.YY9NG+YNO3<W-R>`1W62 QSJA<%SO^I=HUJ`_D0
MI S8_R&6/'ZG)[^LG%L&HL$_?B=#-9Q3J_)GU:[=4-^X>EM9><F,:U%B5X,1
M>+B 03X%%WM,=NUJPI8H*X,YO%/(5OMOBIE#$0H6/3Y_6?/6YU8MKEP1CB?Y
M9ZT'/HU>'^RO7[UFX\*:0'6,"U+O@ 91M^!VN'$I*",XS,!%)KE$.=^DS#B3
MLPHI.70!`"11\3H6;MF]??N6#:\\4.XI$&4 at 9OE05O+T3ETGDF51[!HTD(@F
MD24[<%5UX\IUAC$UU2!!%)A+3,L<LUPD. N+>;0S53U?H+9TVZ:U+S17>0K2
M9, D@ #D98A"9H8D7 at GI\#!"NMN-8,*)<(*!<X H53XR",P4';"="E.F!P#(
M`"!8:D2W=,WF2 DG( !)@T,F#I<K#<.J`--*'=P4<P)%37!+$!A3%.:<&8#H
MS ``(5"_N6%JECO[]B9.S.#0J 6W+""J,Q '^+B4$T V`3$;7+5AVX H.1VR
M4EHJ./W%`"#D^/V!606>#!H7,@!QG=#1K\-4;;A<,A+FN'1";!(HP<$U&Y9)
M($ZHGDW"QL;<PO3LV34`($;C6KQZ\?*'9^8I;IT(5VYP7!XPD>,2X//*"*L"
M$AJ at ZH"J`O$XH$: 9(Q#UP@>R41330QKZB(HF\;$B]TQ<ZCGEZ-"N+/]['=M
M9]J3%A"*< S>L#&W6(8WTX&$Q6"//]TT`<,`+ .P3( X4%5LX.7'8GABJ88I
M7 at 9&-G+RBN<@S5\FDJE98[J()74K&YE#E"2!P>,3$4NF4B:20"0!Q-5;B17&
MT5BI87UM'-.R+7";H[L_BI9O+H5.G3RPUQCK/"$!P$!'^X_?ME^^N*FI:D%0
MMY!MIVII<\"P`,L&; L at 3JB<RK$BH&%&M@';$C \8N/(Z:#Q^5?'3G>?W_<^
M)?K:`$0E`#!'_ at I_?W#?%PWW5]08!@FF2>#$8-J :0.6!7AD8&DE84&1"44"
MDDF&R[TQ?+3_U]#1PWM;X\&3+>!:-P`.`.+$B(V&0T/YY0\^5%3H]X,!%@1$
M5""I`T4>H*D"J"DB."4@%C?P=5N?\=:>+]O;#^]YS1@^VPJR!N_X"K>H:'CI
MQ=8S4?- at ET9'0T3[NXG.A8 at TDXB(R+(X_=9U at S;O.A3T%C?L!E,"`(3_W8Z2
M;UKN4V^?//7)F3B=&^84UH at X3TG5I$W[CO<DYS6^<5QPES0!\$QJE^?->[)Y
M^\>]T>Z_=9J at +Z31SG?;KF7-6OTF!.>,NTIY)TSV*"6/?M#2\M,(Z2;1H=.#
MR<7KWSDN^4H;`:1/6G@[CIPY%?6OMEUX_KT3O?[*1UZ'J-Q;RG_'%EE:WMS[
>I(SI=9.NY3C_`'?'9X.OGHHO`````$E%3D2N0F""
end
