[Proj] rHEALPix new parameters
Michael Speth
spethm at landcareresearch.co.nz
Sun Oct 16 19:18:01 PDT 2011
Hello. I updated the source to use the trunk. Here are the updated
changes.
http://code.scenzgrid.org/index.php/p/scenzgrid-proj4/source/tree/master/src/PJ_healpix.c
Thank you for looking over the source!
On 17/10/11 14:14, Frank Warmerdam wrote:
> Michael,
> I see you have not been working against PROJ trunk. PROJ trunk
> has moved to using a "context" structure for thread safety reasons in
> many calls and you are clearly not yet caught up to that. I'm not really
> inclined to make a lot of changes to just get things working against
> trunk. If you can update to trunk I'll take another look.
> Best regards,
> On Sun, Oct 16, 2011 at 5:38 PM, Michael Speth
> <spethm at landcareresearch.co.nz> wrote:
>> Thanks for looking into this. Here is a link to the source. Note, I have
>> combined the healpix and rhealpix (still have more to implement on
>> rhealpix). The spole and npole parameters used can be found on lines 471,
>> 472, 493, and 494.
>> Thanks
>> On 17/10/11 11:55, Frank Warmerdam wrote:
>> On Sun, Oct 16, 2011 at 3:27 PM, Michael Speth
>> Thanks Frank!
>> * New Parameters *
>> For adding new parameters, what is the command line syntax?
>> Example: proj -v +proj=rhealpix +lon_0=0 +a=1 +R_A +ellps=WGS84 npole=0
>> spole=0 -E<<EOF 0 0 EOF
>> This doesn't seem to work. I've also tried using +npole=0 and +spole=0 and
>> also doesn't work. How do I fix this?
>> Michael,
>> I'm not sure. With the "+" prefix, they should be available for pj_params
>> calls. If you provide your code I could investigate.
>> * On Combining 2 Projections into 1 File
>> Typically, there are 2 to 4 Functions FORWARD(s_forward),
>> INVERSE(s_forward), and etc. Would I need to create 8 of these functions (4
>> for each projection)?
>> Yes, I imagine so.
>> Best regards,
>> Michael Speth
>> Scientific Programmer
>> Landcare Research
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
Michael Speth
Landcare Research
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111017/90530ee7/attachment.html>
More information about the Proj
