[Proj] rHEALPix new parameters
Frank Warmerdam
warmerdam at pobox.com
Wed Oct 19 13:54:08 PDT 2011
On Wed, Oct 19, 2011 at 1:35 PM, Michael Speth
<spethm at landcareresearch.co.nz> wrote:
> Greetings,
> How is the tv_out.dist file generated?
Michael,
The file is generated by running the script and renaming the
output file after human review shows any diffs are due to newly
added good results.
> Also, does Proj.4 have any conventions for indicating that a given
> set of parameters for a projection are invalid?
I'm not sure how you mean. In the cs2cs output? In the code? In
the docs?
In the code for PJ_tmerc.c you can see how errors in +zone=
values are reported with E_ERROR() during projection initialization.
Best regards,
> Thanks for your help!
> On 18/10/11 15:41, Frank Warmerdam wrote:
>> On Mon, Oct 17, 2011 at 7:00 PM, Michael Speth
>>> Thank you Frank!
>>> I've added your recommended fixes and it works! We will now start
>>> thoroughly testing. Do you have any suggestions for testing?
>> Michael,
>> Nothing deep, no. But I would like to have a few representative
>> test points to incorporate into proj/nad/testvarious so you might
>> want to consider including that in the submission patch.
>> Best regards,
> Michael Speth
> Scientific Programmer
> Landcare Research
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
and watch the world go round - Rush | Geospatial Software Developer
More information about the Proj
