[Proj] rHEALPix new parameters
support.mn at elisanet.fi
Thu Oct 20 03:17:23 PDT 2011
Michael,
Proj.4 does not have any deep checking for parameters, it is
very basic and simple library. It just usually makes something
wrong without giving any error messages about the wrong
results. There was a discussion about to add a syntax checker
in front of proj.4, kind of a pre processor which would sort out
the most obvious errors. But that addition is waiting for a better
day to be done. Until then the user must be very careful not to
enter anything wrong to it.
Janne.
Michael Speth [spethm at landcareresearch.co.nz] kirjoitti:
> Greetings,
> How is the tv_out.dist file generated?
> Also, does Proj.4 have any conventions for indicating that a given
> set of parameters for a projection are invalid?
More information about the Proj
