[Proj] rHEALPix new parameters
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 31 13:45:19 PDT 2011
On Mon, Oct 31, 2011 at 1:31 PM, Michael Speth
<spethm at landcareresearch.co.nz> wrote:
> Hi Frank,
> There are 4 errors that I want to generate which are only in the inverse
> projections and not the forward. However, the E_ERROR directive seems to
> only work in the ENTRY and SETUP functions (because it returns an int).
> From looking at proj.c, the forward or inverse functions are called after
> the setup code which includes the ENTRY0; I think that I am unable to check
> in the ENTRY0 directive for the error conditions for inverse projections.
> Is this correct?
> So should I use the I_ERROR directive in this case? If so, it doesn't seem
> to allow for entering errno values (its defined as -20). Can I create a new
> directive similar to E_ERROR(err) but for I_ERROR?
Michael,
I would actually encourage you to actually explicitly call
the error code instead of using the opaque I_ERROR
or a similar macro. For instance in PJ_tmerc.c I now do:
* Fail if our longitude is more than 90 degrees from the
* central meridian since the results are essentially garbage.
* Is error -20 really an appropriate return value?
* http://trac.osgeo.org/proj/ticket/5
if( lp.lam < -HALFPI || lp.lam > HALFPI )
xy.x = HUGE_VAL;
xy.y = HUGE_VAL;
pj_ctx_set_errno( P->ctx, -14 );
return xy;
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
More information about the Proj
