[Proj] rHEALPix new parameters
Michael Speth spethm at landcareresearch.co.nz
Mon Oct 31 12:20:05 PDT 2011
Greetings,
    The E_ERROR calls the set_errno function.  Is there a header file
that contains a reference to the error codes for proj.4?  In the case of
HEALPix and rHEALPix, I want to report that for the inverse of these
projections, that the point is not within the projection space.  Also,
for the rHEALPix, I want to report that the values for npole and spole
are invalid.
How should I choose the the values to pass to errno?
Thanks
On 20/10/11 09:54, Frank Warmerdam wrote:
> On Wed, Oct 19, 2011 at 1:35 PM, Michael Speth
> <spethm at landcareresearch.co.nz>  wrote:
>> Greetings,
>>    How is the tv_out.dist file generated?
> Michael,
> The file is generated by running the script and renaming the
> output file after human review shows any diffs are due to newly
> added good results.
>>    Also, does Proj.4 have any conventions for indicating that a given
>> set of parameters for a projection are invalid?
> I'm not sure how you mean.  In the cs2cs output?  In the code?  In
> the docs?
> In the code for PJ_tmerc.c you can see how errors in +zone=
> values are reported with E_ERROR() during projection initialization.
> Best regards,
>> Thanks for your help!
>> On 18/10/11 15:41, Frank Warmerdam wrote:
>>> On Mon, Oct 17, 2011 at 7:00 PM, Michael Speth
>>>> Thank you Frank!
>>>>     I've added your recommended fixes and it works!  We will now start
>>>> thoroughly testing.  Do you have any suggestions for testing?
>>> Michael,
>>> Nothing deep, no.  But I would like to have a few representative
>>> test points to incorporate into proj/nad/testvarious so you might
>>> want to consider including that in the submission patch.
>>> Best regards,
>> Michael Speth
>> Scientific Programmer
>> Landcare Research
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
Michael Speth
Landcare Research
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20111101/71407667/attachment.html>
