[Proj] rHEALPix new parameters
Frank Warmerdam
warmerdam at pobox.com
Wed Oct 19 15:14:53 PDT 2011
On Wed, Oct 19, 2011 at 2:33 PM, Eric Miller <EMiller at dfg.ca.gov> wrote:
> Frank,
> Did you have any thoughts on dealing with the minus zero problem in the test comparisons? I guess some compilers (Intel, others?) will print "-0.00" in some cases which causes the textual comparison to "0.00" to fail.
> See the message from "brick <brickflying at gmail.com>" on 9/27.
Eric,
My suggestion would be that we pick test points that don't result in a
zero result. :-)
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
More information about the Proj
