[Proj] RSO projection
hilmyh
hilmyh at gmail.com
Thu Sep 8 19:16:03 PDT 2011
You did not mention which RSO you are working with -- Variant A or Variant
B.
There has been a lot of discussions on this issue already, for example:
http://osgeo-org.1803224.n2.nabble.com/RSO-gamma-and-Hotine-Oblique-Mercator-Variant-A-td6256795.html
*Hilmy*
On Fri, Sep 9, 2011 at 9:33 AM, gracecwl [via OSGeo.org] <
ml-node+6774427-1986241182-329320 at n2.nabble.com> wrote:
> As I know Proj4 provide rich projection library for open source software
> such as gvSIG. However, when I trying the transformation for WGS84 to RSO,
> it gives me a wrong output. The correct 0utput range should be between
> 2000000,5000000; but the one i get is 1000000,4000000.
> Does anyone has any idea about what should i do for this case. Anyway for
> me to change the code or parameters?
> Grace
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1803224.n2.nabble.com/RSO-projection-tp6774427p6774427.html
> To start a new topic under PROJ.4, email
> ml-node+2062109-505307941-329320 at n2.nabble.com
> To unsubscribe from PROJ.4, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=2062109&code=aGlsbXloQGdtYWlsLmNvbXwyMDYyMTA5fC05MDQ2NDIwNTQ=>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/RSO-projection-tp6774427p6774497.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110908/b29cc86e/attachment.html>
More information about the Proj
