[Proj] Winkel Tripel Problems
Mikael Rittri Mikael.Rittri at carmenta.com
Thu May 10 00:02:15 PDT 2012
Lars wrote:
> ... I wonder why Winkel Tripel is not supported.
Probably because Proj.4 supports only the forward direction
(from Long/Lat to projected coordinates).
>proj +proj=wintri -I
Rel. 4.8.0, 6 March 2012
<proj>:
inverse projection not available
program abnormally terminated
You might think that you only wanted the forward direction, but
for many purposes both directions are needed. I don't know about
QGIS, but maybe they decided to ignore Winkel Tripel completely.
Some years ago, Oscar van Vlijmen gave a link to a paper that
that described how to invert Winkel Tripel.
   http://lists.maptools.org/pipermail/proj/2007-May/002964.html
Another version of the paper was published in the CaGIS journal,
see
   http://lists.maptools.org/pipermail/proj/2008-September/003799.html
Best regards,
Mikael Rittri
Carmenta
Sweden
http://www.carmenta.com
-----Original Message-----
From: proj-bounces at lists.maptools.org [mailto:proj-bounces at lists.maptools.org] On Behalf Of Lars Pennig
Sent: den 9 maj 2012 16:19
To: proj at lists.maptools.org
Subject: [Proj] Winkel Tripel Problems
Hi all,
since I'm working with QGIS (which relies on proj) I wonder why Winkel
Tripel is not supported. I understand that Winkel Tripel is integrated
in proj (+proj=wintri) but that seems not to work. For Example, defining
a user projection with +proj=wintri within qgis and then trying to
project (on the fly) a dataset of epsg:4326 (plate carree) to this
projection fails. Instead qgis shows the existing dataset in epsg:4326.
Anyone out there with a solution?
Thanks in advance, Lars
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
