[Proj] Winkel Tripel Problems
Hamish
hamish_b at yahoo.com
Thu May 10 00:29:39 PDT 2012
Mikael wrote:
> > ... I wonder why Winkel Tripel is not supported.
> Lars wrote:
> Probably because Proj.4 supports only the forward direction
> (from Long/Lat to projected coordinates).
tip o'the day:
for rasters which won't reproject due to one-way projections, convert
each cell center to a x,y,z point, then use cs2cs (or equiv) to do the
forward projection. Regrid the reprojected swarm of points into a raster
at the other end.
In GRASS this is r.out.xyz -> m.proj (or cs2cs) -> r.in.xyz, but most
other general purpose GIS will have the same capability.
e.g.
http://adhoc.osgeo.osuosl.org/grass/alternate_projections/earthquakes_wintri.png
Hamish
More information about the Proj
