[Proj] Memory-Safe C++ API
Fischer, Robert P. (GISS-6110)[COLUMBIA UNIVERSITY]
robert.p.fischer-1 at nasa.gov
Thu May 10 08:51:34 PDT 2012
Is there interest in a memory-safe C++ API for proj.4? I have a basic one here that wraps the C API, although I haven't implemented contexts yet.
--- Bob
/** C++ API for proj.4 Projection Library.
By Robert Fischer: robert.fischer at nasa.gov
April 5, 2012
This file is in the public domain.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
THE AUTHORS OR AUTHOR'S EMPLOYERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
DEALINGS IN THE SOFTWARE.
#ifndef PROJPP_HPP
#define PROJPP_HPP
#include <proj_api.h>
#if 0
class ProjContext;
class ProjStatic {
public:
ProjContext const defaultContext;
ProjStatic();
extern ProjStatic projStatic;
class ProjContext {
projCtx ctx;
public :
#endif
namespace proj {
class Proj {
projPJ pj;
explicit Proj(projPJ _pj) : pj(_pj) {}
public:
Proj() : pj(0) {}
friend int transform(Proj const &src, Proj const &dest,
long point_count, int point_offset,
double *x, double *y, double *z);
// ------------------ Five Standard constructors/methods
// See: http://www2.research.att.com/~bs/C++0xFAQ.html
explicit Proj(std::string const &definition)
pj = pj_init_plus(definition.c_str());
// pj_def = 0;
explicit Proj(char const *definition)
pj = pj_init_plus(definition);
~Proj()
pj_free(pj);
// if (pj_def) pj_dalloc(pj_def);
/** Transfer ownership (move) */
Proj(Proj&& h) : pj{h.pj} //, pj_def{h.pj_def}
h.pj = 0;
// h.pj_def = 0;
/** Transfer value */
Proj& operator=(Proj&& h)
if (pj) pj_free(pj);
pj = h.pj;
h.pj = 0;
/** Copy constructor */
Proj(const Proj &h)
char *pj_def = pj_get_def(h.pj, 0);
pj = pj_init_plus(pj_def);
pj_dalloc(pj_def);
// no copy with operator=()
Proj& operator=(const Proj&) = delete;
// --------------------------- Other Stuff
/** Returns TRUE if the passed coordinate system is geographic
(proj=latlong). */
int is_latlong() const
{ return pj_is_latlong(pj); }
/** Returns TRUE if the coordinate system is geocentric
(proj=geocent). */
int is_geocent() const
{ return pj_is_geocent(pj); }
/** Returns the PROJ.4 initialization string suitable for use with
pj_init_plus() that would produce this coordinate system, but with the
definition expanded as much as possible (for instance +init= and
+datum= definitions).
@param options Unused at this point
std::string get_def(int options=0) const
char *pj_def = 0;
pj_def = pj_get_def(pj, options);
std::string ret = std::string(pj_def);
pj_dalloc(pj_def);
return ret;
/** Returns a new coordinate system definition which is the geographic
coordinate (lat/long) system underlying pj_in. */
Proj latlong_from_proj() const
return Proj(pj_latlong_from_proj(pj));
inline int transform(Proj const &src, Proj const &dest,
long point_count, int point_offset, double *x, double *y, double *z=0)
return pj_transform(src.pj, dest.pj,
point_count, point_offset, x, y, z);
double x0, double y0, double &x1, double &y1)
x1 = x0;
y1 = y0;
int ret = transform(src, dest, 1, 1, &x1, &y1);
return ret;
#endif
More information about the Proj
