[Proj] Proj4-API - pj_init_plus returns a NULL pointer for my ESRI projection string
Markus Eberhard markus.eberhard at InUnum.li
Thu May 10 12:10:32 PDT 2012
Am 10.05.2012 16:56, schrieb Frank Warmerdam:
> On 12-05-10 12:43 AM, Markus Eberhard wrote:
>> Hi *,
>> I'm using the Proj4-API. Currently I've problems with the following C++
>> API call:
>>        projPJ projPixel = pj_init_plus( "+init=esri:21781" );
>> The called function returns a NULL pointer.
>> Strange, the following similar function call works for me
>>       projPJ projPixel = pj_init_plus( "+init=world:CH1903" );
>> Thanks for your help.
> Markus,
> Did you confirm that 21781 is defined in the esri file?  I imagine it
> is as I see:
> # CH1903 / LV03
> <21781>  +proj=omerc +lat_0=46.95240555555556 +lonc=7.439583333333333 +alpha=90
> +k=1 +x_0=600000 +y_0=200000 +ellps=bessel +units=m +no_defs  no_defs<>
> in mine.
> The next thing I'd do is set the PROJ_DEBUG environment variable to 4 and
> try again.  There should be some reporting to stderr about what file is
> opened.
> eg.
> warmerda at gdal65[10]% cs2cs +init=esri:21781
> pj_open_lib(esri): call fopen(/home/warmerda/bld/share/proj/esri) - succeeded
> pj_open_lib(proj_def.dat): call
> fopen(/home/warmerda/bld/share/proj/proj_def.dat) - succeeded
> If that doesn't give a clue you may need to debug into things to figure it
> out.
> Best regards,
Hi Frank,
thanks for your hints. The ESRI projection configuration file is opened
successfully on my system:
pj_open_lib(esri): call fopen(/usr/share/proj/esri) - succeeded
pj_open_lib(proj_def.dat): call fopen(/usr/share/proj/proj_def.dat) - succeeded
Additionaly I've tried to set the projection config string directly
using the following function call:
projPJ projPixel = pj_init_plus( "+proj=omerc +lat_0=46.95240555555556 +lonc=7.439583333333333 +alpha=90 +k=1 +x_0=600000 +y_0=200000 +ellps=bessel +units=m +no_defs" );
-> same result: NULL pointer
I'll try to debug the proj library tomorrow - may be you have an
additional tip for me?
Thanks
Markus
