[Proj] Errors compiling proj4 on linux
Calogero Mauceri
mauceri at actgate.com
Thu May 31 07:41:14 PDT 2012
Great Martin!
the trunk version is compiling now.
Thanks,
Calogero
Il 31/05/2012 16.20, Martin Desruisseaux ha scritto:
> Hello again Calogero
> I just committed a patch where I replaced usage of the C/C++ NAN
> constant by usage of the java.lang.Double.NaN constant in the JNI code.
> If you have a chance, could you test the build again with JNI enabled
> please?
> For the record, I also updated the test suite in
> http://geoapi.svn.sourceforge.net/svnroot/geoapi/trunk/geoapi-proj4/src/test/java/org/proj4/PJTest.java
> Martin
> Le 31/05/12 15:43, Martin Desruisseaux a écrit :
>> Le 31/05/12 14:50, Calogero Mauceri a écrit :
>>> jniproj.c: In function `Java_org_proj4_PJ_getSemiMajorAxis':
>>> jniproj.c:221: error: `NAN' undeclared (first use in this function)
>>> jniproj.c: In function `Java_org_proj4_PJ_getSemiMinorAxis':
>>> jniproj.c:237: error: `NAN' undeclared (first use in this function)
>> Looking on the web, it seem that the NAN constant is not guaranteed to
>> be available on every compiler. I guess that for being very strict, I
>> should returns the value of the java.lang.Double.NaN field (so we would
>> also be sure that it is exactly the value expected by Java). I will try
>> a patch.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
