[Proj] Should we delete the legacy JNI wrapper (replaced by new ones)?
Frank Warmerdam
warmerdam at pobox.com
Thu May 31 12:56:42 PDT 2012
On Thu, May 31, 2012 at 7:30 AM, Martin Desruisseaux
<martin.desruisseaux at geomatys.fr> wrote:
> Since we are at it, the 4.8 release contains new JNI wrappers which
> replace the old ones. The main difference is that the new wrappers fix
> some memory leaks, and are expected to be more efficient by allowing to
> fetch the PJ structure only once instead than for every call to a
> 'transform' method. The old wrappers are still present on the trunk as
> "deprecated" code however. Should we remove them from trunk now? (they
> would still be in the 4.8 branch)
Please feel free to do so.
> Also, should we merge the JNI fixes to the 4.8 branch?
Yes, I think that would be prudent.
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
More information about the Proj
