[Proj] Creating a nadgrid shift file
Jan Hartmann
j.l.h.hartmann at uva.nl
Fri Jan 18 09:01:45 PST 2013
Hi Jose, Gabor, Andre,
I got Jose's program running without trouble, and the results are the
same as what I got with gdal. So the problem is not with gdal, but there
is something wrong with my data. I'll make a detailed use case tomorrow
and hope you can have a look at it.
Jan
On 01/18/2013 11:51 AM, Jose Gonçalves wrote:
> Hello
> I have a program to create GSB files from two long/lat difference
> grids in Surfer format.
> http://www.fc.up.pt/pessoas/jagoncal/coordenadas/write_gsb.exe
> You can check with it. The longitude difference in the input grid are
> in the standard way (east positive).
> Regards
> José A. Gonçalves
> 2013/1/17 Jan Hartmann <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>>
> (Sorry for crossposting, don't know if it is a gdal or proj problem )
> This has been discussed on this list some time ago. I have been
> able to create a working nadgrid file with gdal, but it doesn't
> return the right coordinates. I did it as follows:
> - create a 4 band, float32 geotif, each pixel with the
> displacements in lat, lon (arcseconds), errorx and errory (both zero)
> - gdal-translate it to ntv2-format.
> The displacements in the geotiff are correct, and proj returns
> shifted coordinates when using the ntv2-file, but not on the right
> location. I'm really out of my wits. Could it have something to do
> with ntv2 using negative lon-values east of Greenwich? Any help
> would be appreciated.
> Jan
> Proj mailing list
> Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130118/417b3900/attachment.html>
More information about the Proj
