[Proj] Creating a nadgrid shift file
Jan Hartmann
j.l.h.hartmann at uva.nl
Sat Jan 19 06:56:11 PST 2013
Perhaps I'm doing something stupid, perhaps it cannot be done at all
with grid shift files. I would very much appreciate if you would have a
look at it.
I want to rubbersheet old maps with source and destination control
points in the same projection (epsg:28992). A test example is at
http://mapserver.sara.nl/ntv2.png
The green points are the original points, the blue points are the
locations I want them shifted to. The shift values are in arcseconds,
located at the WGS84 coordinates of the four original points
id | lon | lat | dx | dy
ll | 5.3876 | 52.1561 | -52.6024 | -32.3636
lr | 5.4022 | 52.1561 | 52.5918 | -32.3701
ur | 5.4022 | 52.1651 | 52.6448 | 32.3504
ul | 5.3876 | 52.1651 | -52.63421 | 32.3561
I created a regular grid with gdal_grid, covering both source and
destination points, and with these four points as seeds. Then I
converted that grid to ntv2 format, both with gdal and Jose's program.
The grid and ntv2 files have correct values at the correct locations.
I would expect that a command like the following:
cs2cs +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +units=m +no_defs
+nadgrids=@null \
+to +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+nadgrids=test_shift.ntv2
would convert source coordinates to destination, but no way. The best I
get are the red points.
Is the idea correct? If so, how do I get it to work?
Thanks in advance,
Jan
On 01/18/2013 06:01 PM, Jan Hartmann wrote:
> Hi Jose, Gabor, Andre,
> I got Jose's program running without trouble, and the results are the
> same as what I got with gdal. So the problem is not with gdal, but
> there is something wrong with my data. I'll make a detailed use case
> tomorrow and hope you can have a look at it.
> Jan
> On 01/18/2013 11:51 AM, Jose Gonçalves wrote:
>> Hello
>> I have a program to create GSB files from two long/lat difference
>> grids in Surfer format.
>> http://www.fc.up.pt/pessoas/jagoncal/coordenadas/write_gsb.exe
>> You can check with it. The longitude difference in the input grid are
>> in the standard way (east positive).
>> Regards
>> José A. Gonçalves
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130119/32002158/attachment.html>
More information about the Proj
