[Proj] Netherlands RD (28992) to UTM Zone 32 (3044) produces shifted coordinates
Jan Hartmann
j.l.h.hartmann at uva.nl
Tue Jul 30 03:20:31 PDT 2013
I don't think that that is the problem here. The differences are only a
few centimeters, while errsors resulting from missing +towgs84
parameters are in the order of 100 meters.
Jan
On 30-7-2013 11:57, Milo van der Linden (gmail) wrote:
> Hello Jelmer,
> 1. I would strongly advice to transform everything to wgs84 first.
> 2. wgs84 and etrs89 are based upon different spheroids/datums.
> Transforming from wgs84 TO etrs89 will not be correct if your etrs89
> definition does not have +towgs84 defined. And by default I believe it
> isn't. Take a look at this ticket:
> http://trac.osgeo.org/proj/ticket/15 and see if it is of any help.
> So, what I would do is:
> epsg:28992 -> wgs84 (visual check) -> etrs89
> Good luck!
> 2013/7/30 Jelmer Baas <baas at speerit.nl <mailto:baas at speerit.nl>>
> Hello,
> For a new project we need to convert coordinates from EPSG 28992
> to EPSG 3044 with MapInfo, Oracle AND a few Proj.4 programs
> (PostGIS, a custom DLL, Proj4js). The problem we are having is
> that we're seeing some shifted coordinates.
> First test point (in the Netherlands)
> Origin 135745.924 517131.216
> Proj4js 236345.39474983042 5839505.550959114
> Postgis(1) 236345.390264227 5839505.55017783
> Postgis(2) 236345.394817119 5839505.55055913
> MapInfo 236345.47 5839504.058
> CS2CSN 236345.39 5839505.55
> DLL old(4) 236345.396465174 5839505.54496813
> DLL new(3) 236345.390259674 5839505.55009311
> Oracle 236345.49107424 5839504.12246656
> Test point (in Germany)
> Origin 254870.45 415123.56
> MapInfo 350265.960 5731670.259
> Postgis(1) 350263.4072329 5731667.880
> Postgis(2) 350263.4132521 5731667.880
> DLL new(3) 350263.407243136 5731667.88019826
> DLL old(4) 350263.403514925 5731667.88565864
> Oracle(5) 350265.967728329 5731670.33312477
> CS2CS 350263.41 5731667.88 43.92
> cs2cs +init=EPSG:28992 +to +init=EPSG:3044
> It seems MapInfo and Oracle more-or-less agree, as do all
> Proj.4-based products. I don’t know which are “right”, meaning I
> also don’t know which ones are wrong – let alone find the fault.
> Hopefully someone can help me with this problem, or at least point
> me in the right direction.
> (1): "+proj=sterea +lat_0=52.15616055555555
> +lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000
> +ellps=bessel
> +towgs84=565.417,50.3319,465.552,-0.398957,0.343988,-1.8774,4.0725
> +units=m +no_defs "
> (2) Another server where I updated the spatial_ref_system:
> "+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
> +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +units=m
> +towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
> +no_defs no_defs"
> (3) A custom built DLL for usage in VB6. "+proj=sterea
> +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.999908
> +no_defs <>"
> (4) Same DLL. “+proj=sterea +lat_0=52.15616055555555
> +ellps=bessel
> +units=m +no_defs <>”
> (5)select sdo_cs.transform(SDO_GEOMETRY('POINT(254870.45
> 415123.56)', 90112),25832) from dual;
> (5b) The Oracle definition contains some tags I don’t see
> anywhere in Proj.4 (like the Bessel 1841 part):
> PROJCS["Netherlands National System", GEOGCS [ "Netherlands
> Bessel", DATUM ["Netherlands Bessel", SPHEROID ["Bessel 1841",
> 6377397.155, 299.1528128]], PRIMEM [ "Greenwich", 0.000000 ], UNIT
> ["Decimal Degree", 0.01745329251994330]], PROJECTION
> ["Stereographic"], PARAMETER ["Scale_Factor", 0.999908], PARAMETER
> ["Central_Meridian", 5.387639], PARAMETER ["Latitude_Of_Origin",
> 52.156161], PARAMETER ["False_Easting", 155000.000000], PARAMETER
> ["False_Northing", 463000.000000], UNIT ["Meter", 1.000000000000]]
> A side note is that transformation via my DLL doesn’t work
> properly (i.e., coordinates are shifted tens of meters), unless I
> **first** transform to WGS84 and then to 3044. I assume this is
> caused by an easy-to-fix error, but I don’t know what that is.
> P.S.: PostGIS, Proj4JS and my epsg file are all up-to-date.
> Thanks for any help,
> With kind regards,
> Jelmer Baas
> Proj mailing list
> Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20130730/025e6d7a/attachment.html>
More information about the Proj
